Anyone use one of these.....
RE: Anyone use one of these.....
If you can go natural gas then do it. Try to locate something that is direct vented (do a search on the net) Rinnai makes some nice wall mounted direct vent appliances. www.rinnai.us/.aspx/0/c.2e6f2c/Overview <-----(check out this link)
A direct vent appliance uses outside air for combustion and then the appliance vents back to the outside, no open flames.
You can install other gas fired appliances but, they must be at least 18" off the floor.
Dont forget your carbon monoxide detector.
You can also try Hot dawg....they also make direct vent appliances http://hot-dawg.modine.com
If you have any questions, send me a PM, i own a heating/plumbing co. i will try to help any way i can.
I also stayed at a Holiday Inn Express last night, i know all about this stuff.....J/K...
ORIGINAL: petemac
....to heat their garage? Looks good and not expensive.
http://www.heater-home.com/product/G73.aspx
Iron lHorse
11-06-2010 09:02 AM
kansaskid72
12-13-2009 10:16 PM
