Heated gloves
Old 02-04-2012, 08:03 PM
Superfly3176's Avatar
Superfly3176
Superfly3176 is offline
Default Heated gloves
Looking for recommendations on heated gloves and what all do you need to get them tied to the battery? Guess my concern is how long the cord is.
Old 02-04-2012, 08:08 PM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
Check out the Gerbings Hybrids and you won't need to worry about a cord.
Old 02-04-2012, 08:10 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I bought Gerbing brand. Well, actually I bought the liners because they are half the price and I can put them in any glove I like depending on what temps I will be riding in. They came with everything needed to wire right up to the bike. The cord has plenty of slack to run from your battery up through your jacket to the gloves.
Old 02-04-2012, 08:13 PM
Superfly3176
Do they connect to the battery via like a battery tender charger or are they just tied right in?
Old 02-04-2012, 08:20 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
I bought the HD Hybrids, which are made by Gerbings. They are actually made to mate with a jacket of jacket liner, and then that is connected to the battery via either an on/off switch or a variable control.
Old 02-04-2012, 09:44 PM
Jeff648's Avatar
Jeff648
Jeff648 is offline
+1 on liners. If you buy a seperate heat controller, I'd recommend buying a dual controller. Once you buy one heated item you'll probably end up buying more.
Old 02-05-2012, 06:24 AM
skootchnc's Avatar
skootchnc
skootchnc is offline
the cord is long enough to go from the battery, to the rider..... you will have plenty of slack to run it
a) up through the back rest slot
b) foward past the nose of the seat
c) sideways out the middle of the seat
d) any darn way you like
Play around a bit, and see what is easiest for you... to attach, and dis-connect. I run mine forward to the nose of the seat. and can tuck it away when weather is nice
Check out the Gerbings outlet http://heatedclothingoutlet.com/index.shtml Sizes,selection etc change often, so if they have your size... JUMP on it, because if you delay.... you'll miss out
You can go either way.... I prefer the included harness, but you can use the battery tender. You will likely need to up the fuse amps, if you go via the tender (As you add pieces you may have to up the amps on the harness)
+1 on the Dual controller... heated gear is "addictive", I have gloves, jacket liner, and over pants.... I'm TOASTY warm
Old 02-05-2012, 06:43 AM
Captain Itch's Avatar
Captain Itch
Captain Itch is online now
Sponsor
Chances are you will end up with the liner if you are looking in to the gloves..It is one of the best investments you will make,if cold weather is a factor while riding..
__________________
www.Captain-Itch.com
Old 02-05-2012, 06:44 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,358 Likes on 5,498 Posts
Gerbing brand run the pig tail with a fuse from the battery. Try bring it up through the slit in the seat and plug in behind you you often over looked but works well. Get the controller.
Heated Gloves make for a great ride in cold.
Old 02-05-2012, 08:26 AM
knewt5's Avatar
knewt5
knewt5 is offline
There have been dozens of threads about this lately. I suggest you head over to the Touring section and search "Gerbing".
I would reccomend these two threads to start with:
Gerbings: What you need to know
Gerbings Panel Mount Kit Installed
Call Doug it American Trikes in Keene NH 603.354.7740 . He was running a buy one get one half off deal in Jan that I'd bet he'd extend. Best deal you'll find. Tell him Kevin mentioned it on the HD Forum
Quick Reply: Heated gloves
