Heated gloves
Old 02-05-2012, 08:31 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Originally Posted by Superfly3176
Do they connect to the battery via like a battery tender charger or are they just tied right in?
You probably could run a battery tender style if you wanted but I opted to set them up with the plugs that came from Gerbing. Here's why, and I am glad I did. Gerbing uses a simple push in plug. Takes very little force to plug or unplug the connection. Why this is such a huge deal for me, is that I can't tell you how many times I have gotten off my bike with the wire still connected. With the stock plug, it just pops off. Had this been a stiff or strong connection like a battery tender plug, it would have been a problem being tied to the bike and walking away. Same goes for putting it on. If I stop for gas and forget to plug the gloves back in, its a simple maneuver to plug in the plug (while wearing gloves), verses fighting with a battery tender plug.
Old 02-05-2012, 09:56 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Veteran: Marine Corp
If you but the outer gloves, make sure you tell the seller you want the gloves that have a 90 degree angle on the plug. They have elements on the front and back of the glove where the straight plug only has elements on the back of the hand.
ROCKOUT Rocker Products
12-02-2015 03:40 PM
Austin Dave
10-21-2011 10:24 AM
sbcvulcan
09-18-2011 03:23 PM
Jrsess
12-26-2010 07:29 AM
haztaz
12-06-2009 04:24 AM
Quick Reply: Heated gloves
