Thunder-Max
How much worse was your fuel economy? Mine dropped a bit but I expected it since it's running richer. If you look at your map at the Air Fuel @TPS area it will tell you the values. Click on a block on the map and hit the space bar, it will display the setting.
Try posting in the Electrical/Ignition section, you might find the member you want.
That doesn't sound too bad for a heavy bike, but I don't know what it was before. Out of curiosity, what is the AFR at 2560 rpm and a throttle position of 29.6?
You can download the Software for Thunder-Max Throttle by Wire and look at map 187 and it has everything there.
How big a drop in mileage did you see? That AFR is just about where mine is and I know it's rich but runs real strong. It could be leaned out a bit. (I didn't see a 187 map in my listings.) The Zippers tuning manual will tell you how to change it. Now, I always had a buddy tweak my maps since I kept screwing it up. Sorry I can't be of more help.
They have a different set of maps.
You can have both the cable drive TM and the TBW thunder max on your computer
They have two different apps on the screen on your computer and they have two different directories to keep them seperate.
Cardboard, I will make you a map. I sent you a email, read it, gather the information I requested and get back with me and I will send you a map next week. I already have another bilke on the lift and its superbowl weekend and they are all coming to my house, can't miss my own party!
