Let's Talk After Market Drive Belts
Old 07-25-2013, 09:38 AM
zeus33's Avatar
zeus33
zeus33 is offline
Big Kahuna HDF Member
Originally Posted by wisemx
The "slap" is typically what kills a good belt @ higher HP output.
On the strip we've been adding very simple mid tensioners, and a well adjusted belt that has a tensioner can take a beating and be safer than an oil-ring chain.
Some of you have seen what a chain can do if it breaks...
yep, wrap around the front sproket and bust a hole in the case. Better yet wrap around the space between the rear sprocket and swing arm and lock up your rear wheel. No better feeling in the world than going full power in top gear then have your back wheel lock solid. lol.
jakenok's Avatar
jakenok
jakenok is offline
Originally Posted by zoopman
Looks like this company has some belts that would fit depending on model year. I do know that if my rear sprocket wears out I will be contacting this company as I've heard good things about them and their products.
http://www.supermax.net/
that's pretty interesting
Old 07-25-2013, 09:50 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
I was looking at belts for another vehicle...
and some of the ads stated aramid fiber, others carbon fiber. Then there were others still that stated the aramid fiber was what carbon fiber was made from. Don't know what is true, just what I saw in those ads.
Old 09-01-2013, 08:27 PM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is offline
Received 2,694 Likes on 1,271 Posts
Test test
Old 09-01-2013, 10:04 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 49,066 Likes on 17,935 Posts
Chased a couple back down the highway after spitting one out And they can tear the hell out things if it binds seen a starter and ***** of the inner primary get knocked off before .
Old 02-09-2015, 05:21 PM
AZ_Ultra's Avatar
AZ_Ultra
AZ_Ultra is offline
4th Gear
Default Goodyear belts
I had my original belt replaced at 77k, on the 07 Ultra, as it was cracked and missing teeth. It was replaced with a Goodyear belt. At 94k it shredded and left me on the side of the road. No more Goodyear for me.
Old 03-17-2015, 09:05 AM
bbyboy299's Avatar
bbyboy299
bbyboy299 is offline
I had the Falcon Carbon Fiber belt for less than 5K and it snapped in half. will never buy another one. Gates now has POLYCHAIN BELTS
GR89
06-11-2016 10:04 PM
mercman
02-03-2016 10:02 AM
shakrr
09-27-2015 11:53 AM
Son of PMS
EVO
11-08-2014 06:24 AM
fatboyonafatbob32
08-18-2010 03:44 PM
Quick Reply: Let's Talk After Market Drive Belts
