Let's Talk After Market Drive Belts
I have been looking for a stronger drive belt for quite sometime...I'm going to be put out some big power this year (170-180 hp) and i wanted the strongest drive belt possible. I actually spoke with an engineer from Gates and he said the 08s and up use carbon fiber tensile cords and that is the strongest belts currently available so, I'm going to be taking my chances with that belt.
The only other option for me was to change to a chain, but I don't like the fact that oil would be spraying up all over my rim
You got that kinda stick your going to use it same as I do so **** breaks we both know it and belts don't do shock loads well they are designed for continuous steady loaded
+1 on the chain...if your going to crank up the pressure on the pro-charger and make 180HP, a chain is the only way to go. A modern o-ring chain makes little mess...the lube is on the inside.
Them kinda ponies go a chain man , On of the high dollar O-ring jobs will hold up and they are sealed lube so the oil flinging is real minimal .
We will see what happens
I have a 2010 Sportster Custom with 8200 miles and snapped my belt yesterday morning. It's a daily ride and well taken care of. I already ordered a new Falcon belt but hopping you guys could shine some light or point me in the right direction on what could cause a break that early. Doing the install myself and have already done the tear down to install new belt, inspected both pulleys for wear or signs that a rock may have jammed in there. No apparent signs of anything. Any help would be appreciated.
I'm new here but not to riding. This looks like a mighty fine blog.
I have a 98 XL1200S with a few minor upgrades. I have just snapped my third belt. All three of the first belts have been the HD/Gates belts. This time I ordered a Dayco/Carlisle Panther Ultra-Cord. Don't know much about it except the band is supposed to be pretty good. Anybody hear anything?
The best thing about a chain is they are EASY to replace when worn. Like others have stated the O-ring chains dont sling much. I've had a few 70's Harleys with chains. I would turn the oilers off but they still slung a lot.
Just to give you guys an update on this...i still have the same stock belt that i had last time i commented on this thread...granted i don't do hole shots, but i have had absolutely NO problems with the belt and i'm still running 191 hp. I think what really puts un-needed stress on the belts is going WOT from a dig or doing burnouts..which i never do..I'm always flooring it when i'm going at least 10-15 mph
The "slap" is typically what kills a good belt @ higher HP output.
On the strip we've been adding very simple mid tensioners, and a well adjusted belt that has a tensioner can take a beating and be safer than an oil-ring chain.
Some of you have seen what a chain can do if it breaks...
