Screamin eagle super tuner
Old 01-24-2012 | 07:48 AM
WIDERGLIDER's Avatar
WIDERGLIDER
Default Screamin eagle super tuner
OK I've searched high and low on this forum. Will I be able to install the screaming eagle super tuner myself with a laptop? I just have a stage I right now and am looking to get cams, but I want to save some money on the tuner by getting online and installing it first before I have someone do the cams.
I have installed a PCV before but got rid of it.....Are there maps in the Super tuner software or do I have to go through some sort of tuning process once installed? Thanks!
Jon
Old 01-24-2012 | 07:54 AM
RICHIEMACK's Avatar
RICHIEMACK
Are you talking about a sert...screaming eagle race tuner????.if so yes you need a dyno and tune
Old 01-24-2012 | 08:34 AM
WIDERGLIDER
I'm talking part number 32109-08B called "EFI Super Tuner" I guess they call that a SERT?
Old 01-24-2012 | 08:44 AM
RA51's Avatar
RA51
Jon
Yes you can change the map in the ecm with the SESPT.
Yes there are maps in the SESPT software.
You will need to buy the SESPT,cables an cd.
Install cd to laptop, then it has a updater in the software you need to run.
Once software is updated, connect SESPT to ecm with cables.
Have key on an run switch on.
First update the vci in the program. If you do not do this it will not flash map to ecm.
Pick map close to you bike, flash ecm. Do not interrupt flash or you will corrupt the ecm.
When flash is done, on screen will tell you to shut bike off an disconnect vci, wait 10 seconds before starting.
Old 01-24-2012 | 08:55 AM
WS6 Formula's Avatar
WS6 Formula
Old 01-24-2012 | 02:32 PM
WIDERGLIDER
Are the maps easy to read/understand? Like will I see "Stage I air cleaner, v&h 2 into 1"
Old 01-24-2012 | 02:53 PM
Grillfish's Avatar
Grillfish
No after market products listed (i.e VH), just general SE AC, race exhaust, etc.... Find the map that is your yr and close then follow the sticky link from WS6 above if you need help Smart tuning it. Many folks to help you out.
Old 01-24-2012 | 08:19 PM
WIDERGLIDER
Thanks for your help guys....
florida_italian
04-10-2017 03:38 PM
mang0
01-05-2014 01:19 AM
JJHOG
08-05-2013 01:45 AM
downhammer
07-17-2012 07:44 AM
YellowHawk
06-30-2011 09:58 AM
Quick Reply: Screamin eagle super tuner
