Ballistic Lithium Ion Battery
This is suppose to be the best battery for your bike.
Anybody tried one ?
BALLISTIC LITHIUM ION 16 CELL LI-ION BATTERY EVO2
Anybody tried one ?
![](http://www.easternperformance.com/product_images/n/100_013_16cell0015clip__14421_thumb.jpg)
Can you buy a Battery with a 3 yrs warranty on it for your bike ?
Did you look good at the details of it.
Priced new Harley Battery Lately ? Last one I seen was 165.00
And what warranty did it have.
85.00 for a battery with a warranty. Hmmmmmmmmmm
Looking at the same battery for mine or this one http://www.shoraipower.com/p-207-lfx27a3-bs12.aspx , been digging around for a while now for first hand opinions but haven't gotten back yet so good luck .
Is it made in the United States ?
And does it have 500 CC amps
Product Description
16 Cell EVO2 Battery
Dimensions: 112MM (L) x 112MM (W) x 103MM (H)
Positive Terminal Location: Right
Weight: 1350 grams (3 lb)
Voltage (Charged): 13.6V
Amperage: 28 Pbeq A/H
Cold Cranking Amps: 500 CCA
Operating Environment: -18°C (0°F) to 60°C (140°F)
Typical Applications: Large Harleys, 1500cc and up 4 cylinders.
Your powersports vehicle is the pinnacle of modern technology. It is made with the latest lightweight, high tech materials to be the most high performance vehicle on the road, lake, track or trail. You have modified your powersports vehicle with the best in carbon fiber, titanium, and magnesium in an effort to gain every last ounce of performance. Yet, under your seat is a heavy hunk of lead that was designed in the mid 1800’s.
Ballistic Performance Component Batteries use the latest, state of the art lithium ferrous energy storage technology available to provide you with a smaller, lighter, higher energy battery. Each Ballistic Performance Component Battery is assembled by hand in the USA using computer designed custom proprietary cells, cases, and hardware. As a result, Ballistic Performance Component Batteries will provide more energy out of a smaller package while requiring almost no regular maintenance and under most conditions a longer service life than existing lead acid batteries.
Up to 80% smaller than the stock battery
Up to 10lbs Lighter than the stock battery
Service life of over twice a lead acid in similar conditions
Industry leading 3 year warranty
Designed, developed, and assembled in the USA
Hard mounted brass terminals for a direct replacement installation
Completely “dry” technology so batteries can be mounted in any direction
Non-toxic, recyclable, and can be air shipped
Applications for powersports vehicles from 50cc - 1800cc
Tested extensively by professional race teams
Impact and water resistant
No special charger required
No trickle charger required, loses only 10% of charge over a year of static use
It is recommended to purchase the foam adapter for the FL models because this battery is smaller than the stock size
Product Description
I bought the Shoraipower for my 103 FXDXT; was told a couple of things:
1. Do not use a charger with a pulsing/desulfating mode
2. Battery will put out full voltage when starter is being used, as opposed to dropped voltage under heavy draw on an AGM battery; more starter heat if used too long
We are under cover of dark, cold winter right now so haven't put it in my bike...but looking foreward to more cranking power, quicker recovery and less weight. I have the single phase charging system on my '01 and want to keep it stock...this battery and led lighting, including headlight will work fine I'm sure...
The Ballistic is a last option here , I'd have to make a battery box and cover for it or change my pipes out , it's a bastard shape that won't fit mine without a barrel of flying monkeys . If I knew hands down it was up for the job no problem , too much extra work for an " IF " .
Anybody tried one ?
Anybody tried one ?
wscott
12-02-2015 06:25 PM
