overpants ?
Thanks ...I have a heated jacket liner and gloves from Warm & Safe and must agree I love them. Have been using chaps, but just seems the full pant would make more sense in the event of finding the asphalt again
You asked about leather but I'll comment about textile. Tourmaster Venture has a removable quilted lining that I have not needed even down to 35 degrees and a bit foggy in the WV mountains. Not sure how low the added liner would give me.
Davepa, i bought a pair Firstgear overpants at motorcyclegear.com for the $165. I wear 34 waist jeans and purchased 36 waist pants so that I could wear some type of clothing under. They have rubberized zippers and treated leather with inner thigh vents, I use suspenders just makes it all around easier. 10 Year warranty, I have used they warranty for a replacement zipper on an Jacket I have. Best money I ever spent!
http://www.motorcyclegear.com/street...overpants.html
First gear overpants are $165.00 at motorcyclegear.com
Some good recent discussions about leather jacket/coats along with heated gear etc.
Chaps pros and cons have been beat on pretty good as well........
I'm looking into leather overpants...some discussion of the Fox Creek
Anyone happy with the Firstgear?
http://www.firstgear-usa.com/Pants/C...Overpants.html
Any others I should be looking at?
Thanks Dave
Thanks Dave
I have the LeatherUp Xelement overpants and they are killer - you should definitely check them out...here is a link: http://www.leatherup.com/p/Leather-C...aps/54767.html They are only 81 bucks with the 10% off new years coupon code advertised at the top of the page now. And I will go ahead and say it now before the naysayers pipe up...as with most of the LeatherUp products, you have to see this stuff to believe it - the overall quality and thickness of leather is outstanding and you will be very pleased with your purchase!
I use some northface snowboard pants and I have ridden in 20 weather and not felt a chill. Plus they are a cargo pant style so lots of pockets and easy to get in with gloves on
I have a pair of Hein Gericke heavy leather pants that I wear in severe weather..I wear them with some heavy suspenders that I made..very comfortable for long trips when I know the temperature is to cold for jeans and chaps..
Over Pants
If you're not hooked on leather, LL Bean has some Goretex pants that can be over pants or used just with long underwear. They have zippers that go all the way up from the boots to the waist. The have pass-throughs so you can get to your pants pockets underneath. They have suspenders that will detach and built in gaiters. Since they are Goretex, they are water and wind proof and will breath. I think they are priced about $130.00.
I bought a pair of black Guide Gear® 100 gram Thinsulate™ Insulated Work Bibs
so a bargan $25.95 . i bought them one size bigger than normal to fit over my clothing . keep me extra warm on cold rides .
http://www.sportsmansguide.com/net/c....aspx?a=697704
- Lining quilted with 100 gram Thinsulate Insulation for non-bulky warmth
- Adjustable elastic suspenders
- 2 snap chest pockets with pencil pocket. Hand and rear pockets with riveted stress points. Coin pocket
- Leg zippers for easy on / off
- Hammer loop on left leg, utility pockets on right
- Reinforced knees.
- Both easy machine wash / dry. Imported.
