Brass Knuckles (STEEL)
I am in need of some brass knuckles in order to fabricate some highway pegs and passanger pegs. I have searhed for hours trying to locate some made of steel..(Not SS) or at least a definitive answer. I was wondering if the CHROME PLATED are steet or some sort of cast metal...
Anyone know where i can get some? Not intrested in the ready to install deals for 150$
They must be steel in order to weld them up to the mounts I will be making...
Thanks
Thanks
Less than the $150 you quoted... So at $100 and no fabrication needed, it may be worth it to you.
http://www.dkcustomproducts.com/FLYI...K-HDWB-FNF.htm
I just wanna make sure what ever i buy is mild steel and not brass etc..
Why can't you modify those ones to suit your purpose? Just curious, as they are cold rolled steel.
Thanks for the link though..I will definatley keep it in mind!
Check out some chopper sites there's several places selling brass knuckles Kicker pedals and I'm more that a little sure I've seen the pegs too already . Know I've seen them on Ebay lately .
We've been doing that little stunt for a very long time , used to run a set for passenger pegs with quick release pins for easy access . PoPo can take a dim view depending on the stop so a heads up .
