Brass Knuckles (STEEL)
Will I need a special wire?
thanks
You'd need a high end mig , SS wire and the right shielding gas and it will give you an ugly weld anyway . SS needs TIG to done right and one of the cheap inverter DC only units can do it nicely .
+1. If you go TIG try to find at least a 2% thorinated rod or pure tungston and pure argon gas. Prep is 90% of the work. Gotta keep the work clean. Welding is the easy part.
I may go all stainless as well..just hard to buy steel/stuff when i have so much scrap laying around!
I will post up some pix when the time comes!
Maybe where you live - certainly not everywhere. I can own them, carry them and use them legally in KY. In fact, I went to a state government auction the other day where they were selling about a dozen sets of real brass and aluminum and maybe steel knuckles. One of the guys I work with bid on it, but lost.
Your good to go then , just takes some scrap to run a few practice beads with a cheap unit is all to get a feel for the settings . A higher end Tig it's like butter SS is so easy if it's got a little gauge to it and it will mate up to carbon steel very cleanly just don't cool it fast you crack your weld that way . Anything over 1/8" and it's going to take weight or stress with mis matched metals I go Arc , gets better penetration and stabilizes the metals better .
if you got the scrap laying around, cut them out yourself. or get you a waterjet or laser guy to do it. a few buck on his lunch break does miracles around here.
they are easy enough to cut out yourself unless we are talking cutting them from half inch stainless or such.
