Jag or hd cooler?
Old 12-26-2011, 01:17 PM
hellbob37's Avatar
hellbob37
hellbob37 is offline
Default Jag or hd cooler?
Looking at the jag or hd that both mount on the frame downtube. The part I like about the jagg is the ability to add the manual or automatic override for when it's cool out.
What's the opinions?
Old 12-26-2011, 01:52 PM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,747 Likes on 982 Posts
I am going to go with the H D cooler before next summer
Old 12-26-2011, 02:00 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is offline
Back in 09, in 3 issues of American Iron,(Aug, Sept, Oct, I believe) Donny Peterson did a series on oil coolers. He chose the Jagg over the H-D because the Jagg had less "pressure drop". I'll try to explain. The oil has to go thru the cooler "slow" enough for the fins to disipate the heat, yet "quickly" enough to get back into the motor. The Jagg did the better job of the two. I'm planning on putting the 10 row Jagg on my down tubes before next summer.
Old 12-26-2011, 02:37 PM
quikbike's Avatar
quikbike
quikbike is offline
Jagg all the way. Think HD makes theirs?
Old 12-26-2011, 02:38 PM
Morris9982's Avatar
Morris9982
Morris9982 is offline
I'm not sure what you mean when you say override, but both are available with a thermostat so riding in cooler weather should not be a concern.
I had the HD premium cooler on my bike for a while and switched to the fan assisted Jagg cooler. The oil temperature with the Jagg cooler is about 10° lower going down the road than the HD. I can't really compare the around town temperature as the HD cooler did not have a fan.
I am very satisfied with the Jagg cooler.
Old 12-26-2011, 02:45 PM
Hammerhead Pat
And I believe the H-D is an 8 row, Jagg a 10 row
Old 12-26-2011, 03:13 PM
hellbob37's Avatar
hellbob37
I should say bypass valve. I'll try and find the part. Can someone post a link where you guys are buying them. It'll be for a 12 dyna superglide custom.
Old 12-26-2011, 03:27 PM
hellbob37's Avatar
hellbob37
Old 12-26-2011, 03:50 PM
6 gun's Avatar
6 gun
6 gun is offline
oops my bad ! I stuck my foot in my mouth yet again
Oh well no biggie
Old 12-26-2011, 04:00 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
Both are good,Jag maybe cost less than HD !
Quick Reply: Jag or hd cooler?
