where do u hang your
Exactly where mine is.....
Bell Saver
Some HD dealers carry a cool little apparatus that threads into the front wheel axle nut cover to hold your gremlin bell ( if you have a cover installed), it goes in place of the set screw ( use loctite )
The previous owner of my RK drilled a hole it the rear fender skirt. I thought it looked stupid and took it off, the wife thought it should be put back on I said go ahead and she put it up under the lower triple tree. She pointed it out before we when on our next ride, I seen it but it didn't register until I hit the next bump and heard the terrible crunching sound. nice little bell shaped dent in the top of my fender. Now I keep my bell in a field as far as I could throw from the road.
If you don't have an engine guard installed, there are the three open mounting holes, one on each side near your floorboards and the hole in the front upper frame where the top of the guard would mount. Or you could tie it off as others have already mentioned with a zip tie or piece of leather any where you like.
I mounted my ride bell to the bolt at the top of my highway bars on both bikes. I used the frame tab in the top of the highway bars. Been divorced for over ten years this time so my gremlin is gone and not looking for a replacement. Two gremlins down and trying not to get that charmed[cursed] third one.
