Heated gloves or heated grips?
#41
I have heated grips and agree they are good when its a certain temp outside and short commute. Im not sure if its something wrong with mine or not, but after about 30 mins or so they shut off. I am going to buy a pair of heated gloves, so I can use either or. Does anyone have a heated vest and heated gloves? Do they just plug into each other?
#42
IMHO, if you buy even just the gloves buy a dual control thermostat, as chances are you'll eventually end up with a jacket. Gloves always seem to need more juice than the jacket so having the ability to run different settings on the gloves / jacket is almost essential to getting the most out of the gear.
#44
Well I am going to go against the concesus of this thread and say heated grips. The reason is that they are always there. You can not forget to bring them or not have room to pack them. When you are 100 miles from home and all of a sudden the temp drops and you are not dressed for it. The grips are there and will keep you from freezing up. Gloves may provide better heat, but most of you will not have them with when you need them. You will spend more time wishing you had them than enjoying the heat they provide. I have had heated grips on my last 3 bikes and I would not be without them.
#45
I'm in agreement with NDBadlands. I have an old set of heated gloves somewhere, I haven't used them in years. Too much hassle with the wiring and controller. *If* I knew I were going to be on an extended ride on a bike w/o hand protectors or fairing, and it was in the low 40's or less, I would get the gloves out. Otherwise the heated grips are perfect for me. I have them on a lot, even use them on low when riding in 60-70 degree weather.
.....For those riders who tend not to ride in particularly cold weather, heated grips with hand guards would be the preferred choice. When temperatures do drop first thing in the morning or at night especially on long rides, the addition of heated gloves will become a requirement.
Only using heated gloves will not provide a complete alternative. Look at the back of your hands and you’ll see your veins. Your arteries are on your palm side. This simply means heat your palms and you’ll warm up, heat the backs only and you will stay cold.
However, as it gets colder it becomes obvious that the heated bike grips only heat your palms. In those conditions the heated gloves, which have no heating elements on the palm side heat the back side really well proving to be an effective combination.
It is true that many bikers have a love / hate relationship with heated gloves because of the bulk, they certainly won’t last as long as heated motorcycle grips, horrible to wear when they are wet even if they are warm, and with the benefit of heated grips, bikers can then choose what gloves they prefer to wear.
http://www.heatedgrips.org/debate-of...heated-gloves/
#46
