signal light
Old 12-20-2011, 06:18 PM
scasey's Avatar
scasey
scasey is offline
Default signal light
Flashing faster than normal. it is only on one side and when I hit the turn signal it starts flashing normally but then picks up speed? Don7t know anything about how this works but something is messed up.
I recently had a front bulb go bad on the same side and switched it out. Never noticed anything until today while behind a car at stop light I could see it flashing way faster than normal....any info would be appreciated!
Old 12-20-2011, 09:42 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
Would help if you tell us what model bike you have ?
Old 12-20-2011, 10:16 PM
clicker01's Avatar
clicker01
clicker01 is offline
1. Make sure the bulb you replaced is the right one, not just that it fits, but the correct part number.
2. Take the bulb out and put it back a few times to ensure you have good contact to the filament, and good contact with the socket ground.
3. Check all grounds - a fast flash indicates an issue with increased resistance.
Old 12-20-2011, 10:22 PM
BassCatcher's Avatar
BassCatcher
BassCatcher is offline
Yeah, that.
Old 12-20-2011, 10:39 PM
Mi3ninos's Avatar
Mi3ninos
Mi3ninos is offline
Received 1,762 Likes on 700 Posts
Blinko has an excellent 10W.
Old 12-21-2011, 01:46 AM
oldairboater's Avatar
oldairboater
oldairboater is offline
Wrong bulb.
Old 12-21-2011, 06:00 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
It means you have a trouble code stored in the ECM.
Old 12-21-2011, 08:23 AM
hagger's Avatar
hagger
hagger is offline
My right blinker does that sporadically. It is a loose connection in the housing. Turning it off & back on it works fine. I need to fix that.
Old 12-21-2011, 10:19 AM
Snapdragon's Avatar
Snapdragon
Snapdragon is offline
Good info here.
Old 12-21-2011, 10:39 AM
oldairboater
Where did you get that information? Trouble code storage on my bike is displayed in the time period it takes for the engine sign to go out when you power up the ecm. The longer the light is on the more codes stored I believe.
Quick Reply: signal light
