Low tire pressure warning system for bikes
I bought one of these. It not only shows the pressure in both of your tires, it also triggers an alarm while riding if the pressure drops below a safe level. Don't have to remove tires either. Pretty nice.
http://www.amazon.com/Motorcycle-Tir...3954173&sr=8-2
I don't mind checking my tires manually before I ride, but what happens if you pick up a screw or nail while you are riding? You could have a real problem. This thing warns you while you are riding.
It's a little hard to use that tire gage at 70 mph. I can see a plus for having this system. Going down because of air loss will far exceed the cost of the system............good find
What I don't like about that type of system is that they effectively disable the valve in the valve stem. You are now relying on the caps to hold pressure.
