warning of website
warning of website
Just to let you guys know about this place .
might want to order your parts elsewhere!!
HIGH RPM RACER
You need to get your advertising in order, I/e show one thing ("update your website to the truth".). send another
Especially when you change the part number when sending...i/e ordered 31663-90..you sent 792101..
Bait and switch??
I will post this on the HD forums/metric forums
...Just so I can warn others that you bait and switch
High rpm racer is off my list of places to buy parts from ...
"this is reply from www.highrpmracer.com
This part is the starter clutch only. If you would like to order the
remaining parts we do have them. But if you would like to return this
part we will take it back with no restock fee. Thank you"
Product description/ problem!!!
I ordered Item # 31663-90..pried at 49.95..
the picture of product I ordered included armature.driveclutch/
and other parts ..
look at your advertising on website.
I received part # 792101 only .
can you explain ?????
HIGH RPM RACER
Bait and switch??
and other parts ..
This is what you ordered
http://www.amazon.com/Drag-Specialti.../dp/B000GU5I2E
This is what you received. It looks the same to me & they state it replaces what you ordered.
http://shopping.yahoo.com/782029755-...clutch-792101/
Replaces 31633.90. This all-new replacement clutch utilizes 20% oversize rollers to improve starter clutch performance under hard starting conditions. Will not fit Dyna 2006 Models
and that part number is for a starter clutch. look around the web and see. it's not for a whole starter rebuild kit.
OK , I agree ..however I am not a part number guru.
I simply looked at the picture of the part number they showed..
admittingly it looked like a good deal ..
Why does the website show a "complete kit" ...??No reply neccesary
Companies often use stock photos. Sometimes it is easier than taking an actual product photo, sometimes it reflects where the part goes, sometimes it is to make you think you are getting more than you are. Whatever the reason, it is a common practice.
how about a link?
