F'ing "Jiffystand" Failed
Should be like a big green light that comes on when it's safely locked into position.
Brings up a good point about putting it in 1st when parking it though. Dealer told me to always put it in neutral. Think I'll change that habit.
Not to be offensive, but I believe this is one of the first articles I read upon joining HD forums. Park in Neutral? Never have and never would, even if on perfectly flat ground. bike has the tendency to roll forward because of design. Only way to make sure you bike doesn't slip and fall, is to personally see the detente lock into place each time you set the bike on the stand. If you don't do this each time, you can only blame yourself when it does fall. The top screw did loosen up once on mine and I noticed it because I make the habit of watching the top of stand set into the detente. If it sets firmly it should support you and a passenger sitting on it.
aka Bob
aka Bob
Well after reading the post about HD planning on moving the wheel plant to china it makes me wonder where the "kickstand" is made. I have not examined mine to see if it's stamped with a manufacturing location or not.
Does anyone know?
Ride Safe
Does anyone know?
Ride Safe
Sorry to hear that man. Had mine "try" to fall over once, it was my fault did not have the stand all the way down. Fortunately I was still on it and able to catch it before it went all the way over. Did require some tugging on my part to get back up again.
oh please. where it's made has no bearing. if you watch that damn thing when you park your bike, you'll never have a problem. unlike some of the metric bikes that have no detent or lock, if you use it properly, it will not fail you. just like everything else, if it fails, look back to what you did, chances are, you probably did something half-assed or in a hurry and it came back to bite you in the ****....
It takes such a small down grade to get the bike moving I'm always nervous that most of the time, I put the bike in first and manually push it forward until it stops, then put the stand down and get off.
When I put my kickstand down, I lean the bike carefully while moving it backwards slightly as the stand contacts. That way I know it's definitely locked. I think the Dyna has the best kickstand system.
I don't trust it either, so I always make damn sure I park with the front facing uphill - even just with the road camber. Habit I got into from riding bikes with no detent, which would just roll right off the stand without any help at all. Also makes backing 'er up that much easier...
