Screamin Eagle Hydro Cam Plate and mixing cams parts?
Theres so many ways to go Im just not sure... I want to run a andrews 21 cam with the Screamin Eagle Hydro Cam Plate. Would it be bad idea to mix the andews cam with the Screamin Eagle cam plate? Do I need the andews 21n or just the andews 21 cam?
Mag, did you ever get info on above said? Andrews TW 21 or call the hotline and talk tp Gary himself, Good Luck, D
847 - 759 - 0190 phone
Part#288121 TW21 10/30 220 255 .498 .134 Stock Bolt-in cam: More torque for all around riding with heavy
40/08 228 264 .498 .121 bikes, stock compression ratios and stock pistons.
Similar to #23 cam for EV80. (1700-4800 RPM).
