Proper Tire Balancing
Dyna Beads work for me and a couple of friends use them. Tire must be off the floor for installation and follow instructions. They are reusable for next tire purchases.
When I wrenched on cars years ago, I was always taught the dot on the tire is for lining up with the valve stem. But you still need to balance the tire. It doesn't make it automatically balanced just from doing this, it makes it closer by making up the difference from the weight of the valve stem. I always cringe when I see tires with the dot not lined up with the stem, and it seems to be most of them. It's there for a reason and no one does it.
+1 Dyna Beads. As far as the dot lining up, I often rotate the tire to get balanced without weights. Takes extra time but no weights. The Dyna Beads are nice because there constantly adjusting so as the tire wears they will rebalance. There is a noticable difference in the feel expecially in the front wheel.
OK guys; I just googled Dyna Beads, and that looks like a good thing. Guess I will have to try them to see what I have been missing. Thanks for the heads up on this.
Any of y'all tried a fluid balancer call 'Ride On'? Right off the bat, it is NOT the same stuff as 'Slime'. It dynamically balances the wheel/tire assembly and self seal small punctures in the tire, for the life of the tire. I talked to one of the mechanics at an independent shop and he loves it in his crotch rocket. I'm thinking about giving it a shot.
When I had my current rear tire put on the rim, I talked to the owner/indy of the shop and he said he could put the weights on the inside of the rim on the hub. I told him to go for it. Anyway, about a month later I was rolling the bike out of the garage for a wash and heard this tinkling sound as I rolled the bike. I figured out pretty quickly what it was. Took the tire off the bike and back to the indy. When they broke the bead and got access to the inside of the tire, there were many little lead fragments running around inside.
After remounting the tire, I can't tell any difference between the weights and without.
Go figure.......
Go figure.......
Go figure.......
Go figure.......
