softail in cargo van
Hi
Has anyone got any experience fitting a heritage softail into a cargo van? The opening in the back of the van with both doors open is 48" high by 48" wide. Also can someone give me the dimensions with handle bars tops to ground level with stock bar? I plan on removing windshield and loosening the bars and turn them down somewhat if I have to. I plan on making a ramp out of 2x10's one beside the other held together by 2x4's and set it on the drop down of the bumper.
Here's the bike I hope will fit.
Man, that's gonna be one hell of a tight fit. Also, is the van long enough for the bike to get all the way in? And then how are you going to tie it down?
I think I'd find a friend with a truck or trailer, or rent a trailer. May save you some headaches.
The van is 9 feet from the back doors to behind the seats. I was going to put a length of 2x10 behind the seats , push the bike up against the 2x10, the van walls is the bare metal frame type with lots of tie down spots.I hate trailers, I had bad experience with a utility trailer. I've never been up close to a heritage but I think it would be compareable in size to your roadking so I'm hoping worst case senario will be remove the windshield and loosen off the bars and lower them.
Hi
Just take a tape and do some measuring before you commit yourself that's all , sit on the bike hold it upright and measure to the highest point on the bars then do the door frame simple and pull the mirrors even if it does trust me on that one .
My wideglide front to back is like 92" or something like that. It's just a p-hair shy of 8ft. A heritage is gonna be a little shorter due to the decreased rake...
Length-wise should fit but I'm with the trailer/pick-up idea. Getting a bike into a cargo van is not going to be fun at all.
To the OP, what bad experience id you have with a utility trailer? Was it due to your negligence?
I've used a 4x8 utility trailer many times to haul my WG around the southeast. It had 12" tires and every time I used it (wasn't mine) I blew at least one tire.
My buddies dad use to have an old Marlboro panel van that was red and had no windows. Just a 1992 Chevy van, and it worked perfectly for his RK. Put a hoop between the front seats and a small electric winch by the doghouse. He even had a custom license plate that read HOGPEN on it. Worked like a charm and when he had the bike out it gave him a great place for his sleeping bag and gear.
campdreamer47
02-04-2021 05:27 PM
