V&H quiet baffle questions
I love loud pipes, but my bike seems to have gotten louder and I can't start it up at home or work without everyone knowing. I have an 01 fatboy with v&h BSS with regular baffles. I am thinking of changing baffles to v&h quiet or BCT QQ baffles. Got a few questions:
1. How do v&h quiet baffles compare to regular v&h baffles - both noise and performance?
2. Is BCT QQ baffle quiet - how do they compare to v&h baffles? I heard a few video clips and they seemed pretty loud.
3. Do the BCT baffles really give much performance over other aftermarket baffles? Website makes many claims, but comparing mainly to exhausts with no baffles or cut baffles.
4. Is there any difference in construction between regular v&h baffles and their quiet baffles, or is it just wrapped in insulation?
2) Can't answer
3) Can't answer
4) There's a difference in construction & their wrapped. I installed them in my Longshots & they definately sound better (deeper) & are noticeably quieter but still NOT quiet. Worth the $$ IMO.
Can't answer any of your questions but I have a set of V&H QBs on my floor waiting to go in. Maybe I'll get in done this weekend. If I do I'll take some before/after video for you.
I installed the V&H quiet baffles in the Short Shots on my Fat Bob. They are a little quieter, especially when riding at low RPMs. They still have a pretty good bark when you roll on the throttle. They are wrapped with what looks like fiberglass, but I think it is burning out relatively quick. The original baffles are a straight through design, where the quiets have a solid end with holes around the outside. Didn't notice a difference in performance, but I don't think my bike was tuned the best when I bought it anyway. Still working on that. BTW, I put anti-seize on mine when I installed them, they should come out easier if I want to change them out.
They're quieter but the stock packing doesn't last long and once it's blown out it's as loud as the stock baffles again.
I now run FMF packing from a 4 stroke dirt bike and it's quieter and lasts longer than the V&H.
I added Hardcore baffles later and they quieted it way down. Not too crazy about the sound, but it is what it is and better than stock pipes for sure.
They will lower Ur sound 2-3 DB's, some say 4-5 DB's, but they have a deeper note.
Regular baffle
V&H's Q baffle.
The V&H's Q baffle
The V&H's Q baffle is made quite different. The reg baffle has no room for the wrapping on the outside of it.
Regular baffle
V&H's Q baffle.
The V&H's Q baffle
I had the V&H quiet baffles in my slipons. What was said about them above is correct.
Replaced them with BCT QQ's because I felt there wasn't enough difference going from the stock V&H to the quiet baffles. The BCT's had a much deeper, fuller sound, which is what I was after. And they were anything but quiet. As for performance, if there was any difference from one to another it was minimal.
Thanks for all the responses - a lot of useful info. I am most likely going to get v&h quiet baffles and rewrap with better material when needed. I recently added some se204 cams using a canned map for the PCIII (unfortunately, only map available is for 203 cams), but I think I am going to get a tune and custom map here in the next couple weeks. I am going to install the QB baffles first to get the best tune possible. Bike runs good and strong, but I can't wait to see how much smoother and more power can come from a good tune.
