Building a Custom Chopper
Old 10-16-2011 | 10:17 PM
zukeeper's Avatar
zukeeper
And it comes full circle , we did our best to get away from the jockey shift in the 70's . Might look kool but about as useless as ****' on a nun when comes to day to day riding . Been there done that .......
as a jockey rider I must disagree.............now if you want to talk about useless.....maybe we should talk about kickstarters lol
  #32
Old 10-16-2011 | 10:43 PM
TwiZted Biker's Avatar
TwiZted Biker
Not when you running 11.7-1 compression and no release they aren't , those expensive starters most days don't do it . Kicker is easy if you know how to tune your bike .
My jockey days included drum brakes and mountains so maybe I'm a little biased
  #33
Old 10-16-2011 | 10:47 PM
zukeeper's Avatar
zukeeper
bored tonight ...just figured I'd rattle your cage
but why arent you running releases ? I'm asking because they are in my future plans
  #34
Old 10-20-2011 | 04:04 PM
traveler's Avatar
traveler
More than likely doesn't want to pull the heads off a bike that's running just fine.
  #35
Old 10-20-2011 | 05:10 PM
TwiZted Biker
Big inch shovels and that hemi high domed compression chamber & piston add a big *** .600 lift cam using the gas we have today will ping and knock like crazy over 10-1 comp , best work around and that helps with several little PIA problems is dual plugs . I'm a die hard backer of that set up on big shovel motors , take my bike as its configured now give it a good canyon run pull one set wired and and make the return trip there's a very noticeable difference almost like a 200lbs ghost passenger doesn't have the sharpness at the throttle , start's harder and of course knocking at lower rpm ranges & doesn't like to idle steady anymore .
Kicker and I got well acquainted in the 70's & 80's so it's no big thing for me no bad knees but that's a factor for a lot guys , I know my bike and tuning her has been refined down to fine art over 30 yrs we've been together .
Evo's don't benefit from duals near as much so comp release's are great idea for them , I'd lose ground .
  #36
Old 10-20-2011 | 05:13 PM
TwiZted Biker
Man this forum is getting flaky double posting in every thread now , I suspect it's gonna crash just a matter of when .
fat_tony
03-25-2015 10:21 AM
Simple Man
12-18-2012 01:34 PM
Leesiple
Custom Models
14
05-18-2008 09:20 PM
turbo38sfi
Motorcycles For Sale
05-29-2007 10:56 AM
aal
11-25-2006 11:15 PM
Quick Reply: Building a Custom Chopper
