Dehumidifier in Garage/Shed
Old 10-12-2011 | 09:15 PM
babalu's Avatar
babalu
I don't typically put the bike into storage for the winter, I'll ride right into January but Jan, Feb, and March. But I'll be honest I can go weeks at a time before I can get the bike on the road in upstate NY. I guess I always had this problem but I had an old evo sporty I didn't really concern myself about it, it was a beater, once a year I busted the rust and rattle canned it, it looked decent you had to really look hard to notice. This bike in my signature has a year in that garage and I have some bits of rust in spots, I saved a long time to buy this bike, even though it's used and not a nice shiny new one I busted my *** for it and it's a rider but I'll admit the rust is pissing me off.
The wife isn't going to like it but I'm designing a ramp to get the bike in the house for Mid Jan, Feb, and March, and I'll look into some of the other solutions for Nov, Dec, and Jan. Going to have to fill a column with cement in the basement to support the bike and move the dining room table over, but it's doable.
Old 10-12-2011 | 09:52 PM
dixiedawgg's Avatar
dixiedawgg
Originally Posted by sharpshooter
What about a bubble haha.... Dont think a humidifier would do much for ya unless it was one big unit.
Don't laugh, I use one of those for a big VW trike my Dad and I built. It sits out in a carport, under a roof but no other protection, and it does a GREAT job even in this Florida humidity, I would recommend it to anyone. Slight PITA to get on and off but not too bad once you have a little practice.
This is the one I have: http://www.calcarcover.com/product.aspx?id=73&cid=179
Old 10-12-2011 | 09:59 PM
zukeeper's Avatar
zukeeper
box fan
Old 10-12-2011 | 11:03 PM
Data's Avatar
Data
6th Gear
The dehumidifier will not keep up with the air flow in a building that is not tight. Fan would probably be better than the dehumidifier.
Any of the bubbles that the others have suggested will work great. The Harley one is nice and keeps the bike dry and getting the bike out occasionally is easy. If you add a light like HD7585 suggests it will even be better. With the bubble just a 20W bulb would help.
Cheers
Old 10-12-2011 | 11:37 PM
BLKBAGGER's Avatar
BLKBAGGER
Mount a ceiling fan over the bike. Cheap and they don't suck much juice.
Old 10-13-2011 | 12:46 AM
FXD07's Avatar
FXD07
Veteran: Marine Corp
Dehumidifiers will freeze up if it gets under 40 degrees......wash, wax, good cotton cover (breathable) , put a light bulb under it. If you ride when there's salt on the road, you HAVE to wash it off before storing.
Old 10-13-2011 | 06:58 PM
BassCatcher's Avatar
BassCatcher
Damn, man. Pouring concrete? Just get a joist support. They are adjustable and pretty cheap, any building supply can get you one.
Old 10-13-2011 | 07:06 PM
Shredding rubber's Avatar
Shredding rubber
Originally Posted by HD7585
Get a good bike cover. Zip tie a 100w drop light under your engine. The heat from the bulb will rise and fill the cover and keep your ride dry. Cheap and easy solution
Genius
Old 10-13-2011 | 07:34 PM
babalu's Avatar
babalu
They have the columns you just fill with quick-krete, no big deal takes a couple minutes to mix. I already have the adjustable joist, but the bike + wood stove I put in two years ago is a lot of weight, I would feel better with a concrete filled column.
Old 10-13-2011 | 07:52 PM
oldairboater's Avatar
oldairboater
Wax the bike tins and chrome. Park it on plywood. Put a cheap fan blowing on it and work on your door seals. Even a rubber flap makes a big difference on doors.
Quick Reply: Dehumidifier in Garage/Shed
