AMP Research EZ-Pull Clutch
Old 10-11-2011 | 04:21 PM
nomad1221's Avatar
nomad1221
4th Gear
Default AMP Research EZ-Pull Clutch
I've been looking into putting a clutch assist on my 2006 Sportster and found this one. Not long after ordering it, I saw a review about it that talked about how it stopped working while she was riding and caused her to have an accident. She also mentioned that H-D or some other mechanic refused to put it on bikes because of the mechanical problems. Since I've only heard good things, other than this one post, I wanted to find out if anyone else has heard of or experienced any problems with it before?
Old 10-11-2011 | 04:41 PM
dogwithtwodicks's Avatar
dogwithtwodicks
Stage III
have you heard of rekluse,,emf or pro start auto clutch can be seen on youtube, no need for a clutch then.
Old 10-11-2011 | 07:02 PM
nomad1221's Avatar
nomad1221
4th Gear
That sounds awesome, but it's a little expensive for me right now.
Old 10-11-2011 | 08:19 PM
xwhyz1959's Avatar
xwhyz1959
http://www.phatperformanceparts.com/...=CC-CLUTCHLITE
I'm running the XX-soft in my Sporty.
Old 10-11-2011 | 09:18 PM
nomad1221's Avatar
nomad1221
4th Gear
Did you notice a big difference after installation?
Old 10-12-2011 | 08:32 PM
xwhyz1959's Avatar
xwhyz1959
Oh yeah! If you have any time on your Sporty, the clutch ramp may even have small detents worn onto it where the ***** sit during normal riding. In that case, when you pull in the clutch lever, the first thing you have to do is get the ***** out of the little worn spots first, and that can be where all your effort is going.
Old 10-20-2011 | 12:03 AM
nomad1221's Avatar
nomad1221
4th Gear
I just ordered the Clutchlite xx-soft, so I'm hoping that takes care of it. Thanks again.
Old 10-08-2012 | 05:52 PM
RobV10's Avatar
RobV10
Default Correct Side
I noticed in the instructions that is says to pull the cover from the right side but doesn't the clutch cable feed into the left side of the bike? It may be nit-picky but i've never messed with the trans on a Harley.
Old 10-08-2012 | 06:12 PM
RA51's Avatar
RA51
I have used this clutch assists in a 95 sportster an then removed from 95 when sold an put in my wifes 04 sportster now. This works very good for the wife.
http://www.phaedruscycle.com/
RSDUDA
Milwaukee Eight (M8)
47
08-11-2022 12:53 PM
AlanStansbery
13
11-13-2016 08:34 AM
Freedomrider13
02-23-2014 01:46 PM
rowle
03-25-2013 06:32 AM
MAC1950
04-03-2009 07:09 AM
