Oil coming from rocker cover?
I replaced my both my upper and lower rocker boxes. I hope its not the same bolt, but i did have to cut an allen wrench to make a tool. Cut about an inch or so off a mismatch allen wrench and then used a wrench to tighten the bolt... That was the worst bolt to tighten, i dont remember which bolt however. It may have been under the cover, but just another thought if you cant get any other tool to fit.
And im glad its not leaking today, maybe it was a fluke...
Yeah, I hope so. I'll be watching it pretty close for the next few days. Thanks again for the help and suggestions.
Yep, road it home in hotter weather and it did come back. This time, instead of one little trail, there are four little trails. And I don't have the right size tools to mess with it.
So I called the dealer where I got it, and they said it didn't sound serious and the soonest they could look at it would be next Thursday. I don't think so. It's my only transportation right now and my days off are Monday (shops closed) and Tuesday.
So I called the other dealer in town and they are going to look at it tomorrow when I get off work. Of course, they may not be able to fix it then as they'll only be open a couple of hours by then. But at least they'll look at it and get me fixed before the end of next week.
What could cause this? I mean, it's got 3200 miles on it now. It's been in extreme temps of 113 and 42 degrees. It's been on a 1020 mile round trip. And it's had it's 1,000 mile service a couple of weeks ago, with all synthetic used. What would cause this now?? I always let it warm up before taking off in the mornings. And it's never had cold water on the hot engine. I'm at a loss as to what could cause this all of a sudden. I want to clean it off so bad, but want it to be present for them to trace back to the source!
No need to remove the tank just get one of these...
http://www.mactools.com/shoponline/p...mn08-0220.aspx
Nice tool. But if doesn't have a couple of bends in it, it won't get up under the tank. Here's the best picture I have of the area. Note the position of the tank over the forward most bolt on that rear cylinder. That's where I think the oil is coming from. What's eating at me more than anything, is why did it just all of a sudden start leaking?
![](http://img.photobucket.com/albums/v247/Danny45/2011RoadKing8-23-11.jpg)
If possible, try and clean up any debris at or near where the leak is coming from so you can locate the leak...Degreaser and some water is a good start...It may be simpler than it appears!!!
Same problem just started on my evo. About 5000 miles on it. The bike had sat for about two years before I bought it. Tried to tighten things up, but looks like the gaskets are done for. The leaks gettin bigger.
About to pull the tank and change gaskets. Wondering if anything I need to look out for while cracking it open. New to this......
Also, I'd guess most haven't had an evo and don't have a clue what the differences are - myself included.
My suggestion - Start a new thread in the EVO section and you'll get answers from EVO people.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
The way it trailed down from the top, it looked like it was coming from the area of that one bolt that is up under the tank. Is it possible that bolt is loose and it's coming from there? It's the first time I've seen it, and like I said it wasn't very much at all.
Looks like I need to take it to the dealer.![Frown](https://www.hdforums.com/forum/images/smilies/frown.gif)
If the gasket is leaking "torguing it down" is not going to fix it, once it leaks it has to be replaced. Luckily a rocker gasket replacement is real easy.
