Been running the HD Temp gauge, push button readout. Not crazy about it but it was a gift. Do these read out hotter than the actual temp, how accurate are they?
Because you mention a "push-button" I assume you're referring to the dipstick gauge. I've had one in for three years now and feel that it's fairly accurate for both oil temp and level so far.
I thought about getting one, but I know me and I'll get obsessed with always looking at the temperature. VTwins run hot and I"ve what I can do help with the heat. I already know that a stock TC runs around 240-260. One with a 10 row cooler runs 20-30 degrees cooler. That's all I want to know.....What I do know is I want to ride, so I'm climbing on my steed and putin a couple hundred miles on it before lunch......see ya
You can check the accuracy by putting it in boiling water, it should read about 212°F.
