HID HEADLIGHT
RE: HID HEADLIGHT
I just put one in two weeks ago, it pretty simple to install, you just have to get the the back of the housing. If you have a dresser with a fairing you have to pull the fairing off, and it right there. Let me know if you need more detail, I might even have a pic I could show you.
RE: HID HEADLIGHT
How is the lighting. Is it brighter than the stock one? I have a friend that has a BMW with this type of headlight and it seems to be 10xs brighter than mine.
RE: HID HEADLIGHT
I just went up to the dealer and got the one they had there, it wasn't the Kuryakyn, but it is an HID ($25). Yes it is brighter, hard to say how much, I could see fine with the old bulb, I was looking to get a bulb that would get me noticed more (by the cages) when I drove at night. But I can tell you this, there is a huge difference when I hit the high beam!
I'm sure they do make them for the 02 Lowrider as well, I had one in my 04 Dyna Superglide Sport.
As far as the install, its the same as changing a burned out bulb. The key thing is to not touch the glass portion of the bulb, the oil from your hands will cause the bulb to fail prematurely.
RE: HID HEADLIGHT
That's what happends when you have oil in your hands...Prematurely
I want to get passing lamps but it might be cheaper if I go with the HID Light!
Thanks for posting this I was going to ask the same Question!
RE: HID HEADLIGHT
That has to be a different kit, I just installed the HID bulb into my exisiting projection headlamp, but on my Dyna, I put it in the factory headlamp, which was not the projection type.....It is still is a very bright - white light. Not sure what kit you are talking about, do you have a link?
RE: HID HEADLIGHT
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Try this, If the link does not work it is Harley part number 68094-06a
