Road King owner's PSI concensus.....
Old 08-21-2011, 07:26 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Default Road King owner's PSI concensus.....
Just curious what RK owners are running for front and rear PSI's. I'm doing 40#Rear and 36# front.....how about the rest, what's the concensus?
Old 08-21-2011, 07:50 PM
CSP067's Avatar
CSP067
CSP067 is offline
36/40 but I have the original Dunlop ride-flat po-leese tires.
Old 08-21-2011, 08:03 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Didn't know they made ride-flat tires for bikes, (I need to get out more!) I'd like to hear more about that.
Old 08-21-2011, 08:19 PM
RayBoy's Avatar
RayBoy
RayBoy is offline
36/36. Always solo. What the manual says. Wondering if I should run higer in the rear (stock Dunlops)...
Old 08-21-2011, 08:26 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
I ride solo also, the manual says 40 rear and 36 front, but I hear different pressures and I want to make sure I'm not running too light. I want the tires to last a long as possible so I thought a thread was needed. Besides I havn't posted a new thread yet and I need to for the inevitable future when I need help from the masses.
Old 08-21-2011, 08:49 PM
AnotherBlackSG's Avatar
AnotherBlackSG
AnotherBlackSG is offline
I just aired mine up last week, but can't remember what the psi was. I usually ride 2 up & have always gone by what's stamped on the tire. Are you sayin' that's incorrect?
Old 08-21-2011, 09:14 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
No because I've been going by the manual, but I read threads that show PSI's that are all over the place (usually within reason). With this thread, I wanted to build a database of consensus #'s to see what everyone is using to compare with my strategy and see if an adjustment is warranted. For now I'm not going by what the tire says because it gives maximum pressures. The manual gives pressures according to payload/ passenger etc. so you'll need to go by what your total weight between you and the Mrs. are.
Old 08-21-2011, 09:21 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
I don't know about Road Glides, but there have been other threads on this site where folks are running 42/42 with stock Dunlops, which is what I run.
Old 08-21-2011, 09:24 PM
BIGSTEVEX3's Avatar
BIGSTEVEX3
BIGSTEVEX3 is offline
Old 08-22-2011, 06:37 AM
skully1200's Avatar
skully1200
skully1200 is offline
My manual says 36/36. That is what I run.
Quick Reply: Road King owner's PSI concensus.....
