Switching from two up to solo....
Hi guys. My badlander seat raised me up a bit, and although it's fine when my wife is with me, I'd just prefer the solo seat when I'm alone. I ordered a second seat nut so I can easily switch. Here are my questions. When I switch to solo, my fender is already scuffed up from the two up, will a fender bib cover this, and can the bib be left on when the two-up is installed to somewhat protect the fender from further scratching? If not, when the solo is installed, the rear seat nut is exposed, I tried putting the stock seat screw in, but it looks kind of lame, are there nicer "caps" or anything you can put on this seat nut to clean up the look a bit? Thanks!
If the bib is wider than the marks, then YES it will cover them up.
No, I wouldn't think U'd want to leave the bib on with the rear pillion on top.
Go to the hardware store and get a different headed bolt with the same threads.
Ridin'withTheKing
General Topics/Tech Tips
14
09-26-2011 03:51 PM
