LED's Load equalizer
I don't know much about LED's, but am considering installing some.
I have heard they need a load equalizer. Is this the case for all LED lights or only for use in turn signals that flash.
If I am only installing them in the taillight and running lights do I need a load equalizer.
Thank you
Thank you
Correct. If using as just standard lighting (run/park and accent) you just need to wire them up but if being used as turnsignal then yes you usually need to use a load equalizer to keep a correct flash rate.
for you guys that don't want to use the $12 flasher, here's a link that spells it out.
http://tech.bareasschoppers.com/elec...oad-equalizer/
Can you post a link or part # please?
Can you talk through how you installed the EL-12 on the Harley? What year and model? It looks like it is a plug in module but don't think my turn flasher module is plug in.
