ABS kick in at a bad time some times
Your rear wheel locked up (getting on rear brake over metal storm grate).
ABS "pulsed" your brake and gave you the feeling that you had lost rear brake effectiveness. But actually, it allowed you to remain in control.
Without it, you just might have lost control of your bike when the rear wheel starts sliding.
And what do you think would have happened without ABS brakes?
I don't think it was the tire slipping on the metal part sense the drain was only about 10 in. wide . but again I think it was caused by the bumpy uneven section in the black top drive way. I had the front brake lever pulled back tight and as far back as could get it and it was still going forward out towards the traffic. I wasn't on the rear brake because my feet were down ready to make my stop. It just made me look like a rookie but I have been riding motor cycles 53 years. DAMMM I have to get use to those ABS brakes.
It has happened to me a couple times. Harley has a bulletin out for ABS being too sensitive. I let the dealer perform the bulletin and have only experienced this once since. Have never felt it would increase my stopping distance, just thought it annoying. I'm happy to experience that annoyance once in a while for the benefit that the ABS delivers.
Bulletin # is M-1251
It says only for '09's so I assume it doesn't apply to you. Unless they have updated it or release a new bulletin? I'd guess it is working properly though.
Thanks- I'll check with my Harley dealer. But I think it's just something I have to get use to with the ABS brakes. I'll remember that my 2011 has sensitive ABS brakes and that is just what they are.
Ya know, I've been riding for forty years without ABS and haven't crashed because of improper breaking. I've actually done an endo with my '05 RG with no problems. (not on propose). I have ABS on my '09 and will not have it on my next bike if I can avoid it. I don't like it, it kicks in where it shouldn't and really, if you can brake properly you don't need ABS.
I agree with you. I have rode Bikes for 53 years with out ABS and I know you don't jam on the brakes and start a slide especially on a wet road. I learned that my very 1st year on a bike. But I think ABS is going to be a standard part on a bike.
YYipp!!That's the way to put it. I'm glade I'am not the only one to have that happen to.
