stripped torx screw on clutch inspection cover
07-26-2011, 05:20 PM
Any tricks on getting a stripped torx screw out on the clutch inspection cover ?
07-26-2011, 05:28 PM
Been there! Drill it and use an EZ Out extractor. It works best if you use cobalt drill bits. Good luck!
07-26-2011, 05:38 PM
Drill the head off, remove the derby cover, and twist the screw out with a pair of pliers.
07-26-2011, 05:39 PM
Quote:
Originally Posted by
Oldtigercub
+1
I had one on my derby cover. This is how I got it out.
Tom
07-26-2011, 05:42 PM
Once removed use allen head bolts.
07-26-2011, 05:43 PM
I hammered the next size torx socket in mine and got it out.
07-26-2011, 05:45 PM
I went back with a T-27 on a Impact hammer drill and it was able to back it out. Also EZ Outs are a way to go as well
07-26-2011, 05:47 PM
if you could grind it and use a pair of pliers as stated above thats what i would do...BUT if you decide to drill it and ez out it it is best to use a punch and make a indention in the CENTER of the bolt before you put a drill to it.
07-26-2011, 05:59 PM
Just drill the head off and the rest is easy, take the cover off and the screw will come out with your hand!! as said before
07-26-2011, 06:00 PM
get rid of the head take the cover off it will come right out with vise grips
