lubing your cables?
RE: lubing your cables?
I use Rem Oil.
For the throttles, I just take off the throttle side control housing and spray it the cable. Let it soak and do it again.
For the clutch, I take the cable out of the housing, cut the corner out of a ziplock baggie, stick the cable in the hole, put a rubber band around it and spray the lube in the bag. Then, hang the bag up to let the lube run down.
I bought a can of Motion Pro.
I remove the cable so the fluid will run down the cable.I also bought a cable luber.
ericj205
05-16-2011 06:23 PM
