Noise Normal?
Noise Normal?
Got my 06 RK custom back a while ago from its 5000 mile check-up, and it has a new noise. I put another 1000 miles on it now, and I still have the noise. It was not there before, so I thought it might be due to an adjustment or something in the check up. It sorta sounds like those off-road tires on pavement sound. Kinda roars a little now. The sound is definatley coming from the drive train somewere because I killed the engine at 40 mph, and listened to it all the way down to its stop. Hasnt gotten any worse, or better over the last 1000 miles, but I did take it in to have it checked. They told me they couldnt here anything outa the ordinary. I know that all Harleys make different noises, and for Gods sake, I dont want to take it in everytime a 'new noise' comes out cuz I will probbably be there all the time. Just wondering if anyone else has or had this type of sound. Thanks for any input anyone might have.
RE: Noise Normal?
ORIGINAL: BigJohn
Got my 06 RK custom back a while ago from its 5000 mile check-up, and it has a new noise. It sorta sounds like those off-road tires on pavement sound. Just wondering if anyone else has or had this type of sound.
I hear that sound when I drive my Jeep on the street!
But seriously,get yourself a MC lift and put your bike in the air.Then spin the tires and listen.Could be the drive belt.
Some dealers are not helpful.
RE: Noise Normal?
I had read years ago that the biggest reason for break downs on a vehicle can usually be traced to the last person that worked on it.
Another statement was that you should not get normal periodic maintenance done right before you are taking a trip. Either have it done well in advance of a trip or wait until you come back.
This doesn't answer your question, except for double checking what was done during maintenance.
RE: Noise Normal?
It sounds as if the deive belt may be to tight. If it's out of alighnment or too tight it will sound kind of like an off roader. I think that is one of the adjustments on the 5000 service if I'm not mistaken.
