Do I really need a torque wrench?
Old 06-25-2011, 05:18 PM
Jrsess's Avatar
Jrsess
Jrsess is offline
Buy a torque wrench! You'll be glad you did.
  #42
Old 06-25-2011, 05:51 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Originally Posted by SgtThump
... I'm simply asking about whether or not the torque specs and stuff are really important or if it's overkill...
This is a good question.
Understand that, just because a torque range is listed, it does not mandate the use of a torque wrench. This is information. Some ranges given are so wide as to make it obvious that eye-balling is OK. Likewise, common sense and previous F-ups tell us that there are many fasteners whose precise torque is not critical, but whose maximum torque should be severely limited due to fragile materials, for example a plastic lens or soft die-casting.
The most torque-sensitive fasteners will generally be those used to assemble ultra-precision parts (cylinder head,...); highly stressed assemblies, particularly containing dissimilar metals (rear pulley,...); where effective sealing of mating surfaces is important (primary cover,...); and where a moving fit is achieved (steering head,...)...
Once you have the two necessary torque wrenches, it takes hardly any longer to set fasteners to the proper torque--literally a snap! One advantage is that, when checking critical fastener torque, it is EZ to discover a loose fastener, then take steps to determine why (no Loctite?,...).
  #43
Old 06-25-2011, 05:52 PM
chamokie's Avatar
chamokie
chamokie is offline
Never go out in the shop without one..........
  #44
Old 06-28-2011, 10:32 AM
SgtThump's Avatar
SgtThump
SgtThump is offline
Really, really good detailed answer. Thank you very much!
  #45
Old 06-28-2011, 11:02 AM
DGDeuce's Avatar
DGDeuce
DGDeuce is offline
Received 5,863 Likes on 2,354 Posts
Just got the Craftsman $80 torque wrench on sale last week for $40. Can't argue with that.
  #46
Old 06-28-2011, 12:54 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Originally Posted by DGDeuce
Just got the Craftsman $80 torque wrench on sale last week for $40...
Attaboy!
W/ prices like that on quality tools, why would anyone NOT do the job correctly and professionally? There is the added bonus which comes in the satisfaction of a job well done.
My 1/2"-drive ft/lbs was bought on sale at Sears. My 3/8"-drive in/lbs Snap-On was bought like-new-in-case off C/L. In use, there is an unimaginable difference between the two (better is better), but both do the job well.
Sgt--Thanks.
Jinkx
11-01-2012 07:20 AM
upirons
General Topics/Tech Tips
06-16-2009 11:26 PM
peddler
04-06-2009 12:03 PM
1sportytrike
07-11-2006 01:18 AM
campdreamer47
01-30-2006 12:50 PM
Quick Reply: Do I really need a torque wrench?
