how do i stop this bike
Hey all,
im hoping someone here has some knowledge about upgrading or getting a Duo glide to stop. I've just bought this bike (few months ago) and im to scared to take it on the road, as the front brakes really don’t stop. Not sure if its because im comparing it to my Jap bike that has disk brake and hydraulic front end or that this bike is not set up right. It has the original drum brake and cable controlled lever. Is there a way to change it to at least a hydraulic front end but retain the drum brake? In theory the drum brake should stop better than disk as there is more contact surface area than disks but no matter how hard I grab the brake all it does is slightly slow the bike. I get more stopping power from the rear. As 70% braking is done via the front this is just not good. Ive seen people put disks on the front of the duo glides but it really ruins the look of this bike. Could it be that my set up is just wrong? I did adjust the brakes as specified int he workshop manual but it only made a slight difference. Also you need to grab it very hard.
On a side note when I pull the clutch in I get a kind of slight grinding noise. Is there a thrust baring that is easy to change without taring down or pulling out the transmit ion? Sorry for the long-winded story. Hope someone can help though. By the way it’s a 1958 duo glide.
Thanks again
Thanks again
I highly recommend www.caimag.com, but most folks there will want you to keep it stock, LOL.
You can always add disc brakes.
Received 3,349 Likes
So, from your sig I presume it is a panhead Duo Glide?
Front brake...
58 is first year swingarm, first year hydraulic rear. Front has a drum brake. There is no conversion parts to convert a front drum to a hydraulic set up. HD used that front end set up from 49-E77
Disc set ups did not appear until 73 models. Would require different hub and axle components as well as sliders and brake controls, brake lines and a bunch of other small parts.
I have seen pics of folks using later softail front ends as a complete swap to get a modern front end with better stopping power (I think 90-something softail front ends?)
Granted old style brakes are not as good as the new stuff but it should not be an effort to stop. When was the last time the brake linings were redone? Think I would pull it and inspect them if you have adjusted them per the manual and it only slows, but not stops the bike. And if you replace the linings be sure to have the drum turned at the same time. provides a nice clean mating surface when you put it back together and do the adjustments.
Clutch grinding
You haven't said if it is a foot shift or hand shift assembly. You have given no history of the bike so it is a bit of a crap shoot here. Could be something as simple as a linkage adjustment to the mousetrap or tank shift components and rods. Could be something in the clutch hub components. Could be a problem in the top or bottom end of the tranny itself.
Since you have a manual, you might want to disassemble the clutch hub assembly and inspect the components, clean everything, put it back together and readjust per the manual. This is especially true if the bike has set for a while.
Have you seen the bike running before you bought it? Did the prior owner run it through the gears? Did he have any problems with it?
Front brake...
Clutch grinding
You will never get a cable operated drum brake to stop anywhere close to a modern hydraulic disc brake. If it is set up correctly it will stop the bike OK, but will take some getting used to. On those bikes you have to get in the habit of downshifting to slow the bike in a hurry. The grinding noise sounds like the throwout bearing...pretty easy to replace
Hey all,
Thanks again
Thanks again
Was leading shoe technology being applied to the Harley brake shoes back then? With some older cars it is possible to put the brake shoes in backwards which give you poor braking performance going forward and great braking in reverse. Just grabbing at straws here.
Hey all,
Thanks again
Thanks again
Riders are spoiled now they want the bike to ride by it's self stop with mind control.
Drum brakes front and rear fun you need a few skills like drying them in the rain. Clean the rust off it they been sitting adjusted right
