Warming up the twin cam...
How long does it take or how do you do it. I live in a warm climate,so I let it run for a minute or two and ride off easily. I also have efi. I don't hit it hard for at least 5 minutes if not more. Is this necessary?
RE: Warming up the twin cam...
I start the bike and let it run while I get my helmet and gloves on, then back down the drive and turn around, usually the heads are getting warm by then.
I don't worry about it too much. EFI is real easy to live with. I generally only let it idle for 3-4 minutes while I get ready, regardless of the air temp. My carbed Evo was a little more finickey. When it was cold - like in the 30's - it would start on the first touch of the button. But you had to let it warm up a bit before riding off, or it wasn't very smooth.
Start it and ride it. I go easy on the throttle for the first 15-20 minutes during warm-up (just don't rod it). Leaving the bike idle for any amount of time accomplishes nothing but wasting gas.
ORIGINAL: HarleyWood
I let it idle untill the rocker box is warm. Not hot, just warm. At that point the oil should be warm enough to flow easily.
Cold or warm out I go about 30 seconds usually...it's the length of time it takes me to back out of my garage roll down the drive and out into the street then I wait a few seconds longer before I click it into 1st and go. I'm easy on the throttle for the first mile or two then after that...it's game on!
Carb here, pull the choke (I'm sorry, enrichener) out a few notches to let it idle normally, put on my helmet, gloves, etc. and then ride it away. Once it's moving the "enrichener" isn't needed any more.
