J&S Jacks frame bent
Am I missing something here?
First off you know it's a motorcycle lift yet you use it to lift a car.
Second, as you state 'The frame bent from changing tires on a 3500 lb car .
J&S clearly states a weight capacity of 2000 lbs with a lifetime warranty on the frame ..
So you knew it's capacity was only 2000lbs yet you tried to lift va 3500lb car and now wonder why it's bent and are p*ssed with J&S because they won't honor their warranty.
This doesn't add up to me.
If you have a normal midsize car it is assumed a standard craftsman jack will do the job. Which are ALWAYS rated below the total weight of the car.
A 4000 lb jack would normally be overkill on a 4000 lb car. A 2000 lb jack would seem reasonable as your lifting a tire at a time as opposed to the whole entire car from the center with all 4 tires off the car.
Home that clears up the logic behind using a 2000 lb jack on a car
Would never even think to do that especially when a $60 floor jack will work and is what that type of jack is design and built to be used for.
Yes, perhaps J&S should not claim a weight capacity of 2000 lbs but, that is not for me to say. Direct load vs. a offset load. Who knows. Just know I would never use a motorcycle jack to lift a automobile. Period!
Would you use a 2000lb capacity jack to lift 2000 lbs of anything? Or 1800 lbs of anything?
If I own a jack whoses weight rating is 2000 lbs, am I completely out of line to assume it is safe to lift up to 2000 lbs ?
frt or rear ? the rear you would have about 800 pounds on it.. the frt, well thats a whole nother story there.. chalk it up to lesson learned...
take the jack apart and put it in a press upside down of course and straighten it as best possible.. if you ever use it again, support the jack frame in the center with the correct thickness of steel plate..
The physics of the weight was just wrong for the tool. That's why you use the right tool for the right job. It's kind of like using the wrong size socket on a bolt ad then crying because you rounded the bolt's edges.
