Bike stops running above 60 mph
Old 05-23-2011 | 11:23 AM
CVance's Avatar
CVance
Default Bike stops running above 60 mph
A friends 1990 FXR stops running above 60 mph. Pull over and let it sit for a short time and it will restart. You can ride as long as you don't go over 60 or it will shut down again. Carbed bike and thinking it might be an electrical issue. Any help would be apprecitated Thanks
Old 05-23-2011 | 11:31 AM
MetalSpike's Avatar
MetalSpike
Does the bike just shut off or does it spudder, shake, what?
Old 05-23-2011 | 11:34 AM
magna's Avatar
magna
your better off posting this on the Evo site lot of FXR experts over there.
Old 05-23-2011 | 11:35 AM
qtrracer's Avatar
qtrracer
Gas tank venting issue probably, gas caps most likely.
Old 05-23-2011 | 11:36 AM
Mi3ninos's Avatar
Mi3ninos
Agree
Old 05-23-2011 | 11:40 AM
myglide's Avatar
myglide
Check the fuel filter.
Old 05-23-2011 | 11:41 AM
Jim Kraft's Avatar
Jim Kraft
Could also be carb float needs adjusted.
Old 05-23-2011 | 12:28 PM
CVance's Avatar
CVance
Metalspike, the bike just shuts off, not as if it was out of gas. That's why we were thinking electrical.
I'll put this on the EVO page too, maybe someone there has had this issue.
Old 05-23-2011 | 03:08 PM
bagga's Avatar
bagga
replace the main circuit breaker. they get corroded over time and they get weak. when the contacts break you loose power.
Old 05-23-2011 | 03:13 PM
nytryder's Avatar
nytryder
I'm thinkin fuel related, as mentioned above.
Quick Reply: Bike stops running above 60 mph
