Passing lamp bulbs
Received 1,776 Likes
Passing lamp bulbs
Passing lamp. or driving light bulbs, whatever you call them, are so expensive from Harley, I'm wanting to know if anyone has found a compatable bulb somewhere else that is as good but cost less? Maybe I'm just cheap, ( ok, I am cheap ) but $65.00 for 2 bulbs is ridiculous !!!
Thanks !
Thanks !
I bought the passing lamp bulbs for my RK at Autozone and only cost a few bucks. Just take the bulb out and take it to an auto parts store and they'll give you the correct bulb. I don't remember the part number I used.
I believe there's different ones. some are like sealed and some just use one like the headlight H4's.
Just bought two for our Heriage last fall, $14 apiece.
Here it is. Ours take a -- HD # 68453-05
..http://www.jpcycles.com/product/310-387
I looked again,, looks like the 06 and newer models use the one like I got...
mines been through 5-6 headlamps.. in 4yrs, but last summer late, was the first one of the passing lamps went south.
I would still check out your local auto parts store for a 4" sealed beam. May need to modify the connection a little but still better than paying the HD price. I know I've seen on here other topics regarding the sealed beam type bulbs.
Thanks !
Thanks !
Are you sure they didn't quote you for the entire reflector and bulb? I just put one on last weekend after getting hit by a rock. Cost was $32.95, and I was pleasantly surprised when I took it out of the box and there was a bulb already installed.
