Does anyone know if HD breaks in motors?
Back in the AMF days I visited the factory in York, PA. Every bike that came off the assembly line was test run on rollers and all functions were checked. From the posts above, it doesn't sound like they do this anymore.
However; test running a bike is not the same as breaking it in. It takes a while to break in an engine, 500 - 1,000 miles or so.
Taken the tour at York twice, according to what they said and I saw every bike coming off the touring line gets a run on the dynamometer for about 5-10 minutes with a max speed over 80mph according to the displays they have set up. This would not be a break in but just a final test before shipping the bike, but the assembly line ends at the test station and every bike I saw come off the line went into the booth.
These motor are precision machined. The only reason they tell you to break it in to protect them just in case something was not tighten correctly or maybe a crack somewhere. By taking it easy you may catch it say before something really lets go. Lot cheaper that way on them and might be a little harry doing 90 and having an engine lock up. They tell you never to exceed over 85-90 in the manual. 65 is good for me.
what I was wondering is does HD run the motors to seat the rings (and second to test them) and it seems like they do...I have heard that the first several minutes of running a new motor are critical to proper ring seating and if they are not run hard during that time the rings will never seat well....for the rest of the engine and trans etc. the break/ wear in is much more gradual...
Most engines are run hard at the factor to test them, not to break them in. Just because they are run hard at this point does not mean that you should also run them hard. A major part of the proper break-in procedure (short trips, avoid highways) is to heat-cycle the engine and temper it.
A random sample of bikes gets a longer test on the rollers as well.
Matt
