Do you downshift or use your brakes?
#91
RE: Do you downshift or use your brakes?
I do both, I feel that I have more control coming to an intersection with a red light to downshift incase something happens and I have to get out of the way so I don't get caught in a wreck or get hit in the rear. If I have to stop quickly then I will use only brakes, but if there is no need for brakes then I try not use them.
#92
I squeeze the clutch and hold it while I downshift, but I don't let the clutch out. I stop with brakes unless it's an emergency stop in which case I'll let the clutch out for engine braking in addition to the brakes.
#93
I used to downshift but someone pointed out that a clutch replacement was a lot more expensive than periodic sets of brake pads.
Downshifting also put a reverse load on your primary chain, drive belt, and on the transmission gears, which may not be a good thing.
I still do it in the twisties but not often in street riding.
#94
JMXP: That is the same as saying you don't downshift.
ORIGINAL: jmxp
#95
I shift the gearbox down, as I slow down to keep the gear mated up to my speed in case I need to dee-dee-mow out of a situation, but I don't let the clutch out as I slow. So I am downshifting, just not engine braking.
J
J
#96
Jmxp: If that is your definition of downshifting then everyone downshifts. we all have to go to a lower gear or we wouldn't be able to move again.
Downshifting (or engine braking) is using the engine to assist in slowing the bike down. If you keep in the clutch, that is not "downshifting".
#97
ORIGINAL: Fmshiner
Whatever, it's symantics at this point.
I don't use my engine to slow down. I just use my brakes to slow.
#98
Oh. I see what you mean now. You have the appropriate gear ready to engage in case you need it. Gotcha!
ORIGINAL: jmxp
Ok....the difference I think would be those that don't click down as they slow instead waiting for the stop when they go from hi to low all at once.
ORIGINAL: Fmshiner
#99
Ya, me too. You always want to be near the right gear. Hey, that's like a rhyme. I also find most tranny's move down better a notch at a time than all at once ...
#100
ORIGINAL: jmxp
J
J
When I first started riding in the early 60's you had to downshift-brake, particularly going downhill as your brakes would heat up and fade. And you were in trouble if you stopped in anything lower than 2nd cause it was bitch getting back to 1st
