Dyna Bead balancing?
Also makes it much easier to polish your wheels without the wheel weights.
I just put a new set of tires on my bike a couple weeks ago, and I just scooped the beads out of my old tires and put them in the new ones. New tires ride smooth as glass also.
Maybe for those that say they don't work, had tires that were badly out of balance. If they just added some more beads, they'd probably be ok.
The kit that you get has 1 ounce of beads for the front wheel and 2 ounces for the back. If your tire needs more weight than that you just need to add some more beads.
They are totally safe for your tires, and they can be used in tubes as well.
They are definately NOT snake oil. They are not a gimmick. They utilize the laws of physics and work like a charm.
When using wheel weights, you can balance your tires for a certain speed, and they can be out of balance at another speed.
With the beads, they are a variable balancer by adjusting themselves as needed at any speed.
btw, I don't sell Dyna Beads nor am I affiliated with them in any way.
I just tried them and found that they work as advertised. I'll never go back to wheel weights.
Here is a youtube video showing the principles of centramatic balancers. Its not using Dyna Beads, but it works the same way, to give you an idea of how they work.
http://www.youtube.com/watch?v=skY6qvzpNXI
Since I change my own tires and ride 8-10k miles per year I am sold on them.
Are there are any OEM motorcycle or automotive manufacturers using this sort of balancing mechanism?
If not why not?
OEM manufactureres specifiy tighter out of round, and out of balence requirements than replacement tires have to meet; and they are still balancing thier tires with external weights if I'm not mistaken. If throwing a handfull of dynamic weights in a tire would remove the need to balance a tire with external weights, I have to believe that it would be the far less expensive sic less labor intensive solution. OEM's are in fact just as cheap as you all suspect . . . if they thought for a second that they could get away with this method you can bet in a heart beat that they'd be there . . . Duh!
Even when racing we'd true the tire, with what essentially amounts to a lathe, and then use external weights. also secured with Duct Tape . . . a bit of insurance to keep the corner workers happy.
If not why not?
Received 24,128 Likes
If not why not?
If not why not?
