Need Advice-TIRE ISSUE
Old 04-25-2011 | 04:07 PM
HDATTY's Avatar
HDATTY
Default Need Advice-TIRE ISSUE
I need your advice. I was out of town this weekend and had a rear flat. The motorcycle repair place, in a small Texas town, had only a Dunlop Cruise Max to fit my bike, a 2008 Heritage. I now have a AVON Venom on the front and a Cruise Max on the back. Any problems running two different brands. Any experience with the Cruise Max over the Dunlop 401 or 402. I need your comments. Going on a 5 day road trip and do not want handling problems. Also, do not want to spend extra $$$ to match tires if it isn't a problem. Thanks for your responses. I trust you guys.
Old 04-25-2011 | 04:23 PM
Zap's Avatar
Zap
I don't see a problem, I very seldom have matching brands, front to
rear. Also, nothing wrong with a Dunlop.
Old 04-25-2011 | 04:36 PM
Primo's Avatar
Primo
Due to a similar circumstance I ended running a Metzeler Marathon on front and an Avon Venom on the back. Totally different tire and pattern.
Ran that way for almost 6k until a nail took out the Avon.
I'm guessing you will be perfectly fine.
Old 04-25-2011 | 04:49 PM
walkerinin's Avatar
walkerinin
I have a Metzler on the front and a Dunlop on the rear right now (thanks to a 3 inch bolt taking out a brand new Metzler on the rear)
Old 04-25-2011 | 04:51 PM
Gliden's Avatar
Gliden
My understanding is as long as you keep bias ply and radials away from each other you'll be ok.
Old 04-25-2011 | 05:00 PM
HDATTY's Avatar
HDATTY
Thanks. I just wanted to make sure. At least both tires are whitewalls so they look good. I drove 100 miles back home and didn't seem to have a problem. Hard to tell with 25mph winds hitting me sideways.
Old 04-25-2011 | 07:14 PM
ia2189's Avatar
ia2189
Metzeler on the back, stock Dunlop on the front. No handling issues.
Old 04-25-2011 | 08:08 PM
piasspj's Avatar
piasspj
Sounds like a good test to me.
Old 04-25-2011 | 08:19 PM
MisterPX's Avatar
MisterPX
Depends on what kind of riding you do, generally you'll want teh front to have teh same or better grip than teh rear.
Old 04-25-2011 | 09:28 PM
oct1949's Avatar
oct1949
used to be don't mix radials with bais..
But on the sons 09 NT it came with a radial on the rear and reg bais on the front when new.
Quick Reply: Need Advice-TIRE ISSUE
