What adhesive for grip
Old 04-19-2011, 08:22 AM
CobraEd's Avatar
CobraEd
CobraEd is offline
Default What adhesive for grip
What is the best adhesive to use for the left rubber handgrip???
Old 04-19-2011, 08:26 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
I have put on several grips over the years and they have all been so tight I have never used glue. The new ones I bought always came with some glue, that I landed up throwing away. I have had people tell me that hairspray actually works well, but I have never tried it myself.
Old 04-19-2011, 08:28 AM
05RdKing's Avatar
05RdKing
05RdKing is offline
none - they are fine "as is", no need for glue
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
There is actually a grip adhesive. Buy a tube, use a little bit of it, then save the Damn thing forever. They should sell it in single use tubes.
Old 04-19-2011, 08:30 AM
Triple M's Avatar
Triple M
Triple M is offline
Angle some electrical tape or golf grip tape. It'll work.
Old 04-19-2011, 08:37 AM
softailman1227's Avatar
softailman1227
softailman1227 is offline
Don't use glue, you will end up hating life while trying to put it on. Rubbing alcohol is great. since most of those grips are tight as hell as it is, the rubbing alcohol will lube it up enough to slip right on and then the grip is good to go. If you try using the glue and don't get the grip on fast enough you will have to try to pry it off without cutting the rubber grip and then trying again.
Old 04-19-2011, 09:22 AM
piasspj's Avatar
piasspj
piasspj is offline
I use hairspray, when it's wet it acts as a lube to slide the grip on, when it drys it will hold it in place (but probably isn't necessary).
Old 04-19-2011, 10:24 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,247 Likes on 4,781 Posts
I need to re-glue mine. Now that it's starting to warm up here in AZ, mine has started to slip on the bar when it gets hot.
Old 04-19-2011, 12:02 PM
oct1949's Avatar
oct1949
oct1949 is offline
How bout two sided tape like I use on the grips of golf clubs. it holds plus comes off easy.
use de-natured Alcohol to slid on the grip.
Old 04-19-2011, 01:13 PM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,267 Likes on 1,311 Posts
Glue doesn't hold. Use an even wrap of electrical tape on the handlebar for the length of the grip. It can now be installed by pushing/twisting.
Quick Reply: What adhesive for grip
