1000 mile service and warranty
If you're handy at all it's pretty easy to do. Buy a manual,tools and some supplies that you save by doing it yourself and get to know your scoot.
Dropping it at the dealership and picking it up when it's done is good too.
Keep in mind that the first service includes more than just changing fluids.
You're supposed to check the torque of the critical fasteners (listed in the service manual) and other things on the bike to ensure nothing has come loose or gone out of adjustment, which things sometimes do on a new bike.
I suggest you consider purchasing a service manual and consider doing your own servicing as long as you feel comfortable doing so. You'll save a lot of money in the long run and become more familiar/connected with your bike. If you don't feel comfortable doing any service or doing more complicated service, find a dealer or an independent shop that you trust. Cost is always a consideration but I feel that getting a quality job performed should be the first consideration. If you can find a shop that does what you feel is quality work for the lowest fees, then go there.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
I bought my 2011 Street Glide a couple of weeks ago and I'll hit 1,000 miles very soon. I've changed fluids myself on other bikes and it's simple. But since this is a BRAND NEW bike, I'm tempted to have the dealer do the 1,000 miles service and probably no others. I think it's $275.
I dunno, though. I can save a crapload by just changing the fluids myself. I'm just not sure about checking other things at the 1,000 interval.
A service manual is probably $60 or so. As long as you have sockets, wrenches, screwdrivers, and a torque wrench, you should be fine. I bought the HD oil filter wrench with the notch for the crank sensor. I probably could have gotten the filter off without it but with the filter wrench I know I can remove it. You'll need some Torx sockets to remove things like the clutch cover. Eventually I bought both sockets and t-handle Torx tools as they are more convenient to use on some of the fasteners.
Depending on how you like to work, you may need a torque wrench in both foot-pounds and inch-pounds. I torqued the drain plugs to spec as well as the clutch cover.
You should be able to save $200 or so of the $275 by doing it yourself. Plus as others have stated, you'll know everything is done correctly and you can do it on your schedule without having to drop off and retrieve your bike.
Just keep all your receipts and records of your service so you can document what you did and when (date/mileage). If you wanted, ask other customers that use your dealer or even the dealer service manager if they have any issues doing warranty work on owner serviced bikes. Hopefully you'll never need to use the warranty.
One more thing...you should think about the drain plug and clutch cover seal. I replace mine each time I do a service to help ensure they don't leak.
A number of people buy o-rings for the drain plugs in bulk. HD offers a service kit with three o-rings (one for each drain plug) and a new clutch cover seal all in one kit. That's what I've been using and it works for me.
I do my own and take a pic of the speedo, bike, oil/filter, service manual, tools and do a written log with the items needing checking and the result of each check.
No manufacturer in the US can require that they do the periodic services unless the do it for free. Google Magnuson-Moss warranty act. It's a good read.
Notice the two sizes torque wrenches and the check list? This was the 5K service.
I plan on taking mine in for the initial 1k service and I was planning on switching fluids to AMSoil. Are dealerships usually okay with this, or do they refuse service if you don't use MOCO fluids?
