Why poly handle bar bushings?
Old 04-03-2011 | 11:05 AM
soft 02's Avatar
soft 02
Default Why poly handle bar bushings?
I am still running my stock rubber bushings and I have no vibration issues so what is the advantage of poly bushings? Even after I wrecked my bike on the freeway and folded my bars I just put some 16" apes on and tightened them up and I was good to go. Maby I don't have enough miles to see a need yet.
Old 04-03-2011 | 12:04 PM
softail04's Avatar
softail04
does take awhile but you will see what happens especially with the 16 apes on it.. mine were fine till I put 16's on mine then they needed tightening every other month or so finally replaced them and good to go..
Old 04-03-2011 | 01:08 PM
Toypuller's Avatar
Toypuller
For mine with 16" apes it wasn't a vibration issue as much a wiggle back and forth feeling during accel/decel. Rubber made the bars feel too loose.
Old 04-03-2011 | 02:02 PM
soft 02's Avatar
soft 02
If I have to tighten them 5-10 thousand then I will replace them with poly but so far so good. Thanks for the input. I only asked because I have no vibration and they stay tight.
Old 04-03-2011 | 02:07 PM
Weevil's Avatar
Weevil
Same here. Hate the wiggle, even with the 12.5" one's I have. If I ever consider going any taller, it's poly bushings. I couldn't imagine the wiggle with stock rubber bushings and 16" apes.
Old 04-03-2011 | 02:09 PM
golfblues's Avatar
golfblues
The rubber bushings dry out & crack in 2-3 years. The polys just keep on going....
Old 04-03-2011 | 02:17 PM
soft 02's Avatar
soft 02
I guess i'm just lucky cause mine are 4 years old with 84,000 miles on them and only tightened them twice.
cf7go
04-20-2012 08:28 AM
sedouglas
01-30-2012 01:28 AM
frankiefire702
11-16-2009 08:53 PM
Azgunner
12-31-2007 12:02 PM
shamboogiebanger
05-08-2006 12:48 AM
Quick Reply: Why poly handle bar bushings?
