cams 510 mackies or not.
I just want some input your input is greatly needed. Ihave a 2005 roadking with a stage 1 done so far. I have a set of 510 mackie gear drive cams,also lifters,adj pushrods,s@s gear drive kit.The bike has a 88ci with stock heads right now.Next winter Iam thinking go to a 98ci with stage 2 head work. These cams I hear pull from idle to 5500 and work good with 8.8 to 9.7. comp.My question is are these the cams I want and If so your thoughts about what cam would better and why?
thanks much.
I ride dont drag race just need some more go power.
thanks much.
mackie makes some great stuff, and is a very smart man, my suggestion is to bend his ear with youjr questions, he will be the first to tell you his cams are or are not what you need
