J&S jack or lift table? Pros and cons?
Looks like I'm finally about to buy a house with a nice garage. I'm looking at either a J&S jack or a lift table like one from Complete Hydraulics. If you could only have one, which would you go with? Is one particularly better for certain tasks? I like to do my own wrenching and don't want want to pick one and then wish I had chosen the other down the road.
I like the idea of having a nice lift table but it seems like a good jack like the J&S would provide better access to a lot of areas on the bike. Thoughts?
Go with the lift table. Make sure you get one that secures the front tire. If your worried about getting to the underside of your bike you can always get a sissor jack with a wide footprint. You can get one from Harbor Frieght. I got my table from them about a year ago with a coupon that was in American Iron. Total cost out the door was less than 3 bills. The table is rated at 1200 lbs.
PH
PH
I was wondering what the method was for servicing the forks/front wheel/tire with a table lift. I guess the answer is...you don't.
1 Post
I have both and only use the lift. With the front tire clamped and the black jack scissor jack under the back of the frame, I can change the rear tire. By using tie downs on the back of the bike and the scissor jack under the front of the frame, I can change the front tire or remove the forks. Plus you never have to get on your knees.
I've got both,since I got my table from Complete Hydraulics with the scissor jack,I never use the J&S jack.I can change both front and rear tires using the scissor jack and with a lift height of 33" no more bending over, so its easy access no matter what the task,great addition to the garage for both cleaning and service work.If I could only have one it would be a table lift.I've had the table from C H for 3years now with no problems very good quality,I use it at least 4 or 5 times a week.
Macfhionghuin
Macfhionghuin
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
![](http://images.ibsrv.net/ibsrv/res/src:www.hdforums.com/get/forum/images/icons/icon6.gif)
